Fuel or Fire???
Hey guys, got a 81 911 3.0 CIS. The other day I was driving and all was swell, I turned her off for about 15 minutes then went back and she started up then started spitting and sputtering with half power, after about 3 minutes she cutoff and I haven't got her started since. The car was low on fuel but not out. I have changed the fuel filter and the gas looked like pond water coming out. Please email me personally for tips since I'm posting this off my phone. Thanks!! Warrent22@gmail.com
Old 07-14-2013, 01:10 PM
RETIRED
Joe Bob's Avatar
Use quick start/ether....spray into the intake. If it starts, you have contaminated fuel. Drain everything and refill with fresh fuel.
2012 ML350 3.0 Turbo Diesel
Old 07-14-2013, 01:13 PM
Tryed that.. Nothing
Old 07-14-2013, 03:01 PM
RETIRED
Joe Bob's Avatar
Got spark? Ground out a plug and see if there is a arc to ground. Could be your CD box.
Old 07-14-2013, 03:03 PM
JK McDonald's Avatar
Fuel Tanj Sender -
Hey Warren, Don't rule out a defective fuel sending unit inside the gas tank as the culprit. I had the long thin wire that the float arms strattle break and hold the gauge steady at about a 1/4 tank just outside Chattanooga one time. Just as we were passing an 18 wheeler Frauhelga suddenly begins to sputter and the engine conked out. Luckily we were able to coast across traffic and to an off ramp with only a couple of horn honks and one obscene gesture. I told my wife the problem shouldn't be gas because the red low fuel warning light wasn't even on. A short hike later to a nearby filling station had us back on the road.
If this turns out to be your problem, you can easily remove the outer aluminum cylinder that houses the fuel sending unit and float assembly for inspection. Just be careful and don't lose either of those tiny nuts. The single thin metal wire inside is simply a series loop of sensing element that the float slides along to change the resistance seen by the gauge. I later bought a couple of feet of a similar wire at an electrical shop that rewinds motors and soldered in a new element. Accurately measure about a foot of the remaining old element to know what value of new resistance wire to use.
My repair has been working great for years...
Sorry - I see where you have tried a blast of ether - got to be spark or the muffler bearing could be bad...
Good Luck, Michael
1984 928S - "Miss Purdy"
1987 911SC - "Frau Helga"
1986 930 - "Well Hung"
1975 911 Targa "Blue"
Old 07-14-2013, 03:16 PM
It better not be that box I just replaced that thing two months ago!! But I will check spark and let ya know
Old 07-14-2013, 04:22 PM
kodioneill's Avatar
Pull the sending unit look for contamination in the tank especially the fuel pick up screen.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 07-16-2013, 05:54 AM
wwest's Avatar
Blown airbox...??
Old 07-16-2013, 06:22 AM
docrodg's Avatar
Gas looked like pond water? Low fuel and pond water gas says to me you probably sucked in some water/ethanol from phase separation in the tank that also cleaned up some crud and sent it to the engine.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 07-16-2013, 07:29 AM
porwolf's Avatar
You may want to check the tank fuel filter that is located at the tank bottom. It can easily be done with an empty tank and the car on a hoist.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 07-16-2013, 11:14 AM
fitchn's Avatar
also check your popoff valve under the air filter... if it stuck open it may be causing your no-start issue
Noah
79 SC
minerva blue metallic
Eureka CA / Boulder CO
Physics is like sex, yes there are some practical applications, but that's not why we do it.
Old 07-16-2013, 02:34 PM
Happened to me too. Water and fuel separate in the tank. Once I removed the sender I got about a gallon of water out by siphoning out from the bottom of the tank. Once I got the water out, I was able to start the car and get to shop for proper draining.
Bob D
1982 RoW Silver 911SC - PCA E #339
1997 993 Turquoise Blue Carrera S
Old 07-16-2013, 02:50 PM
