-   -   3.2 base idle question. How many turns? (http://forums.pelicanparts.com/porsche-911-technical-forum/761393-3-2-base-idle-question-how-many-turns.html)
PK 77 911 07-16-2013 03:39 PM
I have to replace the stripped Idle adjustment screw in my 84 3.2. I would like to know what the base setting setting is, how many turns in or out to start from when I put the new screw in.
I have just installed the SW Chip and will be following his instruction re B and C port jumping and setting to 880 instead of 800rpm. Just want to know where to start from.
PK
DRACO A5OG 07-16-2013 09:18 PM
Just fit it in then make adjustments as needed, you will need to do it again after she is nice and warm to verify base idle is set correctly.
