-   -   911sc case split? (http://forums.pelicanparts.com/porsche-911-technical-forum/761459-911sc-case-split.html)
carrerarsr65 07-16-2013 07:31 PM
911sc case split?
trying to split cases 79sc, heres the problem pistons #2/#5 are still below the case spigot,long story short motor locked up tight!! i have all case bolts/nusts removed, the crank will not spin at all, need to get the pisons off before case split any ideas would be great!!!!!! cant get those c clips?:eek:
Tippy 07-16-2013 07:41 PM
Man, never thought of that. That's a tough thing to do. I'd post in the engine rebuilding section, one or more of the shop owners have probably dealt with this and have a good solution.
mazing3 07-16-2013 08:21 PM
can you post a picture of this?
roblav 07-16-2013 09:03 PM
You probably jammed a piston (or two) up against the case. Try rotate the opposite direction. I never remove case nuts until pistons are out.
kodioneill 07-17-2013 06:13 AM
Was the engine locked up before you started the dis-assembly?
T77911S 07-17-2013 07:45 AM
why remove case bolts before pistons?
what about the timing chains. they jammed up in there?
post a pic
mazing3 07-17-2013 08:08 AM
If chains are off and everything else is done I don't see why you can't turn the crank the other way and "un-stuck" the piston. Which is probably really the rod anyway. Pop it with a rubber mallet and some common sense if you have to.
Unless why were you splitting it to begin with has something to do with this.
