-   -   no power to the pots on the coil what could the problem be then (http://forums.pelicanparts.com/porsche-911-technical-forum/761516-no-power-pots-coil-what-could-problem-then.html)
awayne (guest) 07-17-2013 05:23 AM
Thanks Nick so if there is no power to the pots on the coil what could the problem be then? Thanks awayne
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-17-2013 05:23 AM
Power for the coil comes from the electronic ignition unit. Check Fuse 22, it is a 25 amp fuse.
- Nick
