jkeyzer's Avatar
Bilstein shocks for aluminum rear trailing arms
I am upgrading the shocks on my 72T, however it has aluminum rear trailing arms which I understand are not original. Does this mean I need a different set of rear shocks than are listed for the 72 on Bilstein's site?
I believe the ones listed for up to 72 are B46-0167, and 73+ are B46-0169. Which should I get?
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 07-30-2002, 12:38 PM
Early_S_Man's Avatar
Porsche Crest
Jeff,
All '72 thru '74 cars used the same exact OEM Koni rear shocks! Which means that the changeover to the aluminum contrrol arms had no effect on shock application. Order the rear 'sport' Bilsteins for a '74 model ... and I'm sure you won't have any problem with fit!
Surely, the Bilstein site didn't include the '72 models with the '69 thru '71 group!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-30-2002, 01:29 PM
jkeyzer's Avatar
Warren - Indeed they did! 10/68-72 are listed as the older style rear shock.
Make: PORSCHE
Model: BOGE STRUTS (BLACK HOUSING)- 911
Year: 10/68-72
Blank: HD
Front: P36-0112
Rear: B46-0167
Footnote2: Except self leveling system.
Make: PORSCHE
Model: BOGE STRUTS (BLACK HOUSING)- 911 2.3L,2.7L,3.0L (Except Carrera)
Year: 73-3/85
Blank: HD
Front: P36-0112
Rear: B46-0169
Jeff Keyzer
Old 07-30-2002, 01:42 PM
Porsche Crest
Jeff,
Fortunately, for them, most people use catalogs from suppliers that have corrected that error! Otherwise ... they would have a 100% return rate from pissed-off '72 911 owners!
I guess nobody at Biletein was aware that tghe '72 shocks and mounts had to be changed to make room for the 915 installation!
Warren Hall, Jr.
Old 07-30-2002, 02:02 PM
GIBSON's Avatar
When I converted my 73 over to the aluminum arms I thought I noticed a slight change in the fit of the shocks. Seemed like the
geometry was slightly different (I used arms from a '76). The shocks work fine, just seemed like a tighter fit.
Bruce Herrmann
97 C4S
'04 330i
'08 Cayenne S
'07 4.8 X-5
Old 07-30-2002, 02:56 PM
zotman72's Avatar
Just want to add that Porsche used Boge on the lesser Ts more often than the Konis according to my understanding. At least mine were black, blown, Boges when I removed them for Bilstein HDs. There was article in Pano about this somewheres... HTH
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 07-30-2002, 04:55 PM
Senior Member
Hello
Just a moment:
Early 911 steel radius arm had a M12x1,5 bolt and later verions the m14x1,5.
Early Porsche only had Boge, De Carbon, Sachs or Koni coming from the factory.
Bilstein came in 1972 ( basically they where developed for the RS and the Turbo )
Either Koni and Bilstein where options or included in the S-Package.
Grüsse
Old 07-31-2002, 09:32 PM
