HJT911's Avatar
3.2 Carrera, Brake cooling
I'm interested in buying the Brake Rotor Cooling Kit offered by pelican parts.
But, as they mention, there is a risk that this parts may interfere with stock sway bars.
Anyone out there who has fitted those parts to his 3.2 Carrera and is willing to sent some pics.
Any useful information is welcome.
Reg
Hans
Old 07-24-2013, 09:52 AM
I would use the 993 brake deflectors. There should be many threads on this. They will give you plenty of cooling if you remove the rotor splash guards.
-Andy
Old 07-24-2013, 12:23 PM
burgermeister's Avatar
+1 one the 993 deflectors. It's what I use. I run a very mild track pad (ferodo DS2500) and I have no issues with fade. Pads last 8 - 10 trackdays, rotors are 6 years old and about 50% on the way to their wear limit.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 07-24-2013, 02:38 PM
I have had these on my '86 3.2 for years (an older kit, but essentially identical), no issues with fit and the stock sway bar. I put wire mesh over the scoops after seeing how many rubber balls (tire snot)ended up in the rotor vents from track use.
1986 3.2 to 3.4 conversion
Old 07-25-2013, 09:43 AM
