Math lesson: 3.6 +915 = $$$$$
I gambled and lost. I was hoping to get the season out of my stock tranny on the track but looks like I'll be upgrading mid season. This is a picture of a piece of my 2nd gear. I'll be getting the retainer and side-plate upgrade from our host but where should I look for a new set of teeth. I would like to put a second gear set from a 930 (much beefier and a little taller)
Any thoughts?? Tom
Speed Dog's Chauffeur
What vintage 915?
Is it an early 915 with 7:31 R&P or later 915 with 8:31 R&P. To set a benchmark, I have an 86 915 and it was slightly stressed with an OEM Euro 3.2 so it came with a cooler for the Autobahn. A RUF or G50 conversion is a lot of work & $$$$. However, replacing gears is expensive too. A racing 3.6 is a heavy load for a 915. Best of luck.
We have had good service from CMS
California Motorsports - Porsche transmissions, transaxles, gears, differentials, parts, service, manufacturing Give Roger a call -- he is very helpful. They have bins of used trans parts. They just rebuilt a 915 for our 3.8L 911SC race car. There is probably someone closer geographically to you. Matt Monson at Guard in Colorado makes really nice gears and parts too. Are you doing your own work or a shop?? Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
My Good friend Larry is doing the work on it. he called me this morning with the good news that everything else inside is in good shape----got lucky (he already did a rebuild on the tranny 4 years ago).
I just got off the phone with Mat from Guard Transmission. He was very helpful with deciding on the gear ratio. I'm going with 1.65:1 which is a little taller than the stock 1.8:1. This should keep me in the power band going uphill from 2nd to 3rd at our local track. Thanks Mat. I also ordered the one piece bearing retainer and heavy duty side cover and gasket kit. I already have an external oil cooler on the tranny. Hopefully we'll have everything back together for the mid Aug. DE..... as long as customs doesn't delay things. |
gearhead
You're welcome.
Regards, Matt
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
3.6 + 915= That's why they made Visa!
1983 911 SC 2015 Volks GTI 1991 Volks GTI 2011 Nissan Juke 1992 Nissan NX 2000 |
I don't know, I know several folks with nicely built 3.6's bolted up to 915s in track cars that haven't had problems. But they also don't bang gears and run good Swepco fluid which gets changed annually. And have tranny coolers
You'll like the new 2nd gear if you've got some fast 2nd gear turns. I run a 20:32 2nd (1.6) in my 915 and I use it a lot at many of the tracks I run. On the plus side it's good for close to 82 mph with the 7200 redline I used to run with the old engine, and the rpm drop from 2nd to 3rd is very close which is especially nice in close competition. Down side in racing is that I'm too far down the power band for most rolling starts where the pace is usually just 45-50mph to the green flag. But I've run this gear ratio in the past 3 911's I've owned and am quite happy.
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
gearhead
Also, annual gear oil service is too long an interval if you are doing more than a couple of events. I recommend changing the oil every 4-6 weekends. Regards, Matt
RETIRED
Mine went as well, the addition of the WEVO intermediate retaining plate was a worthwhile upgrade.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
RETIRED
