Alternator Issue
I have an '87 911 Coupe. I'm in the process of replacing a bad voltage regulator; I haven't ordered the part yet. I figured I should get the alternator checked out while it was out. When trying to remove the fan off of the alternator, I was banging the shaft on towels on my garage floor and the cap that covers the bearing on the opposite side broke off. I now know what I did was wrong. Furthermore, the fan does not rotate readily anymore. Can a auto electric shop easily repair it or would I be better off ordering a rebuilt alternator from Pelican Parts? If I bring it to a shop, should I have them replace the VR or would I be better off order the VR from PP as it might be cheaper and/or better quality and just have the shop rebuild other necessary items? PP sells two different brands of VR, Hueco and Valeo. Would it matter which one I get, since Hueco is much cheaper?
Any thoughts you have would be greatly appreciated. FYI: I finally did get the fan off safely by using another method. |
Has anyone done this before that can shed some light and help me out please?
Wayne has a DIY post. Pelican Technical Article: 911 Alternator and Fan Replacement & Upgrade
I would buy the VR from Pelican. A rebuild shop will likely charge a lot more for it and if they don't do many 911 alternators (high probability) it will take them a lot longer and more $$ to find one.
When I did this job a few years ago I bought the Valeo and it's worked fine since. No experience with the Huco though. |
By 87, the alts had an internal VR and more than likely have been replaced and upgraded. Local rebuilders tend to have a better rep than remans sold by bulk suppliers. As always, best to bench test prior to install.
Just experience talking. Most if not all remans have a warranty, they don't cover labor. |
Take your pulley half, shims and nut so it can be tested properly, ask me how I know
| All times are GMT -8. The time now is 06:52 PM. |
