SMHemmah
hemmah's Avatar
Overheating
I have a 1969 911T with 1970 2.2L engine with 2.7P&C. Making a 2.5L engine. The engine has been running poorly so I tuned up the engine. All of a sudden I have overheating problems. The engine is running better than it has ever ran.
I verified my max temp is 250-260 when my temp gauge shows max (needle to the right) temp.
I live in a year round warm/hot climate - 75 to 88F every day. I took the heat exchanger off.
Can I remove the oil thermostat and put a plug in?
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank
Old 07-24-2013, 09:09 PM
BW
ruwoodbury's Avatar
If I were you I would remove the oil thermostat and test it, it may be bad, and then replace it. My car was running in the 240-250f range when the air temps were in the 80s. Tested the thermostat to discover it wasn't beginning to open until 250f. After putting in a new one the oil temps now max in the 220s with outside temps in the upper 90s and using a/c.
BW
1989 Carrera--Rebel Racing Suspension, Patrick Motorsports LtWt Clutch Assembly, Enlarged TB, 964 Cams, SSI, Dansk Sport 2-in-1-out, SW Custom Chip, Turbo Tie Rods, Bump Steer Kit, H4s, Vintage Seats RS Replicas, RS Door Cards--and some other stuff
Old 07-24-2013, 09:22 PM
