911sc exhaust 'popping'
This is something I've noticed since removing my CAT and installing a Bursch bypass pipe. I might add that I also had removed the distributor when trying to track down an ignition no start problem. Didn't reset the timing, just put a score mark where the dizzy mounts and reinstalled as precisely as I could (I know, I know, I should stop being cheap and buy a timing light, already).
What happens... when driving at higher rpm's (pretty much all the time) if I immediately let off the throttle the exhaust will burble, pop, sputter. I don't know how else to describe it. It's not really loud, like an explosion or backfire, just kinda noticeable. Thoughts?? |
86FlatSix
Is this similar to this? Fast forward to 2:15 and 3:08 you will hear some popping or burbling on decel.
Porsche 911SC Carrera with Supercup Exhaust with Catbypass Pipe - YouTube
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) Last edited by JQ911; 07-26-2013 at 05:50 PM.. |
If all's adjusted to spec , just enjoy! Burble , pop and sputter as opposed to backfire is what makes these cars special and fun. As long as the mixture's playing a tune with the timing , it's part of the symphony of air cooled sounds
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Decel valves help prevent this condition. Basically you are going lean off throttle. Decel valves ease the rev drop.
see if the decel valve is plugged. a little burble is a feature not a bug.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
JQ911,
Sounds very similar to this 911SC on youtube. Must just mean my car is a healthy and fine specimen of German aircooled flat 6 engineering!! I plan on following my own advice, get a timing light and make sure it's set to spec.. |
The decel valve lets air in, so more of the mixture can burn off in the head. Quote:
'77 S with '78 930 power and a few other things. |
Makes sense but something isn't adding up. I swear my LM2 reads way lean off throttle. Gotta ponder this a bit longer.
Ok. Lifting off brings a rush of air into/around my tailpipe where LM2 bung is attached. Reads lean. Thanks for the correction! Last edited by mca; 07-27-2013 at 06:05 PM.. |
