Question Bosch distributor parts
Anyone know of a supplier of Bosch distributor parts? I am seeking springs, bushings, shims, etc.
Scott
74 914 2.0
73 911 2.4 cis
Scott S.
Old 08-03-2002, 09:58 AM
Early_S_Man's Avatar
Porsche Crest
Scott,
A 'Bosch-authorized' service center may be able to get a few parts, but Porsche doesn't list any replacement internal parts.
Any industrial bearing supply store can get the proper bushings.
A motor/generator rebuild shop may have replacements for the fiber washers, shims, spring washers, clips, bushings and springs that are worn out or missing.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-03-2002, 12:28 PM
I needed some springs for my dist. I called 2 places that rebuild Bosch dists. They both would not sell me parts. One guy wanted $200 to rebuild my dist. and the other wanted $350. For 2 springs. Dicks. I put Chevy V8 springs in from Summit Racing. I got a set of 3 for $5.
I would go with crankfired before I paid someone to rebuild my dist.
You get the same thing when you want an odo. gear.
Rant over
Good luck
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 08-03-2002, 06:13 PM
Cool
A couple of years ago my distributor bushings wore out and let the star piece that spins on the rotor shaft collide with the magnetic pick-up, destroying the magnet inside the base plate. The pricing for any available parts was outrageous, and of course the main piece was unavailable. I found a distributor from a BMW 535 for $50.00, and was able to cannibalize it for the bushings, the hall-effect pick-up, as well as several other pieces, including the base plate .
The only rub was that the BMW spun in the opposite direction, The base plate had a pin that just had to be moved from one position to another for my application. Neither the weights nor the vacuum advance unit were able to be converted, but I think you will find all the parts you are looking for at a very reasonable price given the abundance of six cylinder BMWs in the bone yards. There is probably one out there that spins in the same direction, I just ended my search when I found the parts I needed.
Good luck, I hope this helps.
GT911
81 911 SC
Old 08-03-2002, 07:43 PM
