toddu's Avatar
Hard oil line question
While attempting to get my rear oil lines off I notice that one of the lines running to the front spins at the thermostat even though I can't get the nut on that line off to save my life. My question is, is it going to leak now that it swivels around?
Todd
'81 SC
Old 07-28-2013, 12:47 PM
Am guessing that you've spun the threads off the thermostat housing...
Old 07-28-2013, 01:37 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Todd
Your best bet right now is to split the nut off using a Dremel. With any luck there is no damage to the thermostat threats.
To replace the nut, you'll need the $50 Elephant Racing Nut, work like a charm. Pelican Parts - Product Information: ERMP-0170000
I got 2 of them on the thermostat that has been leaking since I got the car but even with the whole oil line assembly on the floor and using a 16" pipe wrench, I could not loose them. Now its dry like "censured"
Who Will Live... Will See
Old 07-28-2013, 01:52 PM
Could you post a picture?
Todd,
Which oil line is turning? Could you post a picture of the thermostat and oil line? Thanks.
Tony
Old 07-28-2013, 02:05 PM
toddu's Avatar
Hmmm, hope the threads are ok. Nut is definitely stationary and the line is loose and wobbly.
How does the race nut work? Trying to picture how you get it over the flare in the line?
Todd
'81 SC
Old 07-28-2013, 02:07 PM
toddu's Avatar
Originally Posted by boyt911sc View Post
Todd,
Tony
The line that bends below the jake plate insert. I'll see if I can snap a pic.
'81 SC
Old 07-28-2013, 02:09 PM
toddu's Avatar
Went to Elephant's site. See how the nut works now. Interesting. I'll dremel it off tomorrow to see what's going on.
What happened was I had dremel'd one of the rear lines and was going at it with hammer and chisel. Thought I had everything well supported, but apparently not as the line then went loose. I can't picture in my head what might have let go.
Todd
'81 SC
Old 07-28-2013, 02:40 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Some oil lines have a sweated on end (slightly larger diameter that has the flare on it to hold the nut on)...and this is silver soldered or similar to the end of the main pipe.
It might be that this has broken loose from the main line...and after you replace the nut....needs to be re-sweated to make a non-leaking joint again.
The reason for this method...is so that you can replace the nut for repair.
Bob
Bob Hutson
Old 07-28-2013, 03:28 PM
JJ 911SC's Avatar
Todd
Just take your time. I did 2 cut without getting close to the threads and then put a screwdriver and turn it out which broke the nut open.
Old 07-28-2013, 04:18 PM
If at all possible, only use a hammer if you're shaping metal pieces or losing patience. The hammer, especially a BFH, wins most every time.
Before starting, I would have suggested searching the archives for success stories in this area of a 911.
Sherwood
Old 07-28-2013, 04:49 PM
toddu's Avatar
Ok, split the nut (3rd out of 4) and got it off. Threads on the thermostat only have a few "rough" areas and the hard line looks normal. So not sure why it was all loosey goosey.
I'll get the nut from ER and hopefully that will be it.
Todd
'81 SC
Old 07-28-2013, 05:08 PM
JJ 911SC's Avatar
... I'll get the nut from ER and hopefully that will be it.
Todd
I'm sure it will be.
Old 07-28-2013, 05:35 PM
