Replacing rear motor mounts
Newbee question...best way to remove rear mounts with engine still in the car???
you have to support the weight of the engine. i used a jack and engine dolly (same one used to drop engine, basically a furniture dolly with cut plywood on it) but you could probably just use a jack and block of wood.
I just did all four yesterday. I was surprised how much I had to lift the engine to keep it from drooping. The wheel started to slide inward. At first, I had what I thought was a good amount of lift, but the center bolt in the lift never loosened up and the engine dropped about 1/4" after the bolt pulled out. I cranked up a bit more on the jack under the engine and it moved right back up.
Make sure you do just one at a time. If you have AC, the right one is a bit of a bear to get the outer flange bolts out and back in with the nuts below. Mine is an '86 and has the separate nuts and bolts. I think I read that the later cars have integrated nuts below, but I'm not sure. Don't forget the lower large clam washer when re-assembling... Franny |
Figures... Maybe they locked up and they snapped the bolts and had to drill them out. The bolts were yellow Cad and the mounts looked original (yellow cad as well - what was left of them), but who knows.
Well, that would have made the job a LOT easier if they were there. For the center bolts on the tranny mounts I needed a cheater pipe to get them off! Probably close to 300ft-lbs. If tight is good, tighter is better, right? They definitely had been replaced. Thanks for the clarification. I kind of thought mine would have the built in receivers when I started. I was a bit surprised that they weren't there :( Franny |
One other thing to watch for is bending or breaking the engine crossmember. I don't know your location. Corrosion can be a bit of a bear here. This is a good application for an impact wrench. Just tread carefully if you find the mount bolts don't want to cooperate. -J |
Me again...If I just want to drop the engine enough to get at the lower pulley, do I just remove the center bolt??? Thanks to all...
im liking the phone book trick...thanks for the tip. I could probably use a haynes manual and get the same effect :)
| All times are GMT -8. The time now is 09:32 PM. |
