scg scg is offline
scg's Avatar
Question What's this part?
Here I am, happily installing the chain tensioner update when I notice this part... part #31 on this diagram http://www.pelicanparts.com/911/911_Parts/1974-75/1-4.JPG . What is it?
Old 08-03-2002, 05:59 PM
Early_S_Man's Avatar
Porsche Crest
Sure would help if you gave us a clue which engine you have???
On CIS cars, that is the Thermo-Time Switch for the Cold-Start circuit. Other cars just leave the plug in the chain cover in place.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-03-2002, 06:07 PM
Senior Member
Doug Zielke's Avatar
Temperature sensor.
(What do I win?)
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 08-03-2002, 06:08 PM
scg scg is offline
scg's Avatar
Talking
Thanks! You guys are really FAST!
Early_S_Man: Uh, sorry about that . It's a 75 CIS that's being converted to carbs (after overhaul) and finding a home in my 914.
Doug Zielke: A used '75 CIS setup?
Since I won't be using CIS, I guess I'll leave it off. BTW, the chain tensioners are insanely easy to install with the egine out of the car.
Old 08-03-2002, 06:31 PM
Cool
Trivia..on my CIS the part is a thermo- time sw.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-03-2002, 06:44 PM
1bar's Avatar
The thermo-time switch triggers the cold start injection valve (injects extra fuel into the intake rail ONLY while cranking and ONLY when cold). You won't need it on a carb conversion.
Old 08-03-2002, 07:02 PM
