Metal Rescue does it really work ?
Have you tried Metal Rescue rust remover ?
Does it really work ? I have some parts that are rusted and would like to use it. In their videos it works like magic, are those true ? |
Banned
Stuff with phosphoric acid in it will make rust into iron phosphate. But if the panel has cancer, this stuff will only slow it down a little. Surface rust? Works fine for that.
Always Be Fixing Cars
I've used a great number of phosphoric acid based rust eaters. They are like magic on surface rust, but considerably less magical on gnarled/pitted/deep set rust. They just take longer and need some brushing/scrubbing. My recommendation is Naval Jelly (available at autozone and Home Depot) because it has the right consistency to hold onto all sides of a part rather than running off. If you're de-rusing an old wrench, sure liquid is good, but jelly is better for most automotive applications. Wear protective gear.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
AutoBahned
they all run the RedOX rxns back the other way - i.e. reduction
some have tannic acid or some such in them and will cause some other rxns to an organic compound - might be a chelate, can't recall - there is an old thread where I did some research on this and posted it |
I suspect you may have already completed your project, but if you have any doubts about Metal Rescue please feel free to contact us with any questions, and don't forget we do have a money back guarantee.
Workshop Hero ™ 517-546-1117 aford@armorvci.com |
