brake caliper rebuild -piston brake seal ATE
What is the purpose of the yellow mark on the internal ATE piston seal?
thank you .
Old 03-20-2016, 05:28 PM
cashman's Avatar
I believe it's so you know its orientation incase you accidentally twist it during installation. Whichever side it's on new in the box is the side it should be on when installed in the bore.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 03-20-2016, 05:35 PM
It is on the inside of the seal, so when installed ,the yellow mark side, (dull side )is down and the shiny side ) is the top side or seal side .
Maybe thats the reason .
it is impossible to turn it inside out and install it ,as it will not stay that way, unless you force it.
still curious.
1979 SC
1986 Carrera 3.6 L+
Old 03-20-2016, 08:09 PM
