1 Attachment(s)
Well it ain't 9000 RPM, I can tell you that! :(
That's exactly the way it felt when I drove it, Jim. Actually, it was so anxious to pull strongly beyond the redline, I was afraid to go there (with a car that wasn't mine.) I can hardly wait to install the 20/21's in the 'Bomber. My set arrived just last week. |
nah fuel limiters are pretty rough... think about it, no fuel = running lean... running lean = melting ****.
7000 is probably safe, 9k is valve float city, as evidenced by c. striets pistons & valves... to safely do that you need stiffer valve springs & retainers, maybe lighter valves and certainly a hot cam. pz |
Using some BMEP calculations, I came up with the following examples for 3 liter motor to illustrate what needs to be done to make HP.
* Assuming an engine which generates a BMEP of about 145 psi (which is comparable to an E and a stock SC. See below for some comparisons.) This is how fast you will need to spin this motor to generate the following Horsepower numbers: * 200 HP = 6000 RPM * 250 HP = 7500 RPM * 300 HP = 9000 RPM * 350 HP = 10500 RPM Now "wilder cam's", higher CR and such will often give higher BMEP's. Here are some example peak HP BMEP's to give you some idea of the range: * WW1 Albatross Benz Motor: 108 psi * (Ferrari) Dino 246: 138 psi * BMW K100: 148 psi * Early Ferrari 308: 149 psi * US Spec Ford Zetec SVT V6 (4 valve): 150 psi * Honda CBR 1000 (4 valve): 152 psi * FF1600 "Kent" motor: 155 psi * Kawasaki ZX11 (4 valve): 159 psi * Suzuki GSXR 1100 (4 valve): 160 psi * BMW K1200 LT/RS (4 valve): 164 psi * Early "S" Motor: 164 psi * Yamaha FZR 1000 (4 valve): 169 * Porsche RSR 2.8: 171 psi * Eagle Weslake 3.0 V12: 180 psi * Ferrari 360 GT (FIA/ACO): 183 psi * Dale Shaw Mazda GLC SCCA GT5 motor: 185 psi * Porsche 917 5.4: 192 psi * Porsche 917 4.5: 197 psi * Cosworth DFY F1 engine (4 valve): 203 psi * Honda 2.0 F3 engine (4 valve): 204 psi * Nissan Supertouring 2.0 (4 valve): 248 psi :eek: That will give you an idea of how hard you'll have to work to increase the BMEP. You can then do the BMEP = function of (HP, Rev's) calculation yourself: BMEP = HP * 792000/(Displacement in inches * peak HP rev's). Note I've tried to consistantly use european (DIN?) HP. Be careful because SAE HP will make the numbers look noticably higher. |
| All times are GMT -8. The time now is 05:25 PM. |
