-   -   Shifter spring install (http://forums.pelicanparts.com/porsche-911-technical-forum/763914-shifter-spring-install.html)
hemmah 08-01-2013 03:46 PM
OK I did it. I removed the 2 springs in my shifter and I can't get them back in. See photo.
Any suggestions on how to get the springs back in?
Or can I not put the springs in and just bolt the plate back in?
1969 911Thttp://forums.pelicanparts.com/uploa...1375400754.jpg
hemmah 08-03-2013 04:45 PM
How to put shift springs back in
Folks I figured out how to get the springs back in the shift. I had to cut the springs down by 1/3 put then in with a bolts and lock-nuts. Lesson: don't take the springs out of the shift:eek:
See the photos:
Start with bolts, lock nuts, lock washers, springs and shift:
http://forums.pelicanparts.com/uploa...1375576676.jpg
Add bolts, lock nuts, lock washers, cut sprints down by 1/3 and shift
http://forums.pelicanparts.com/uploa...1375576738.jpg
Tighten nuts on springs and lock nuts on shift body. Tighten springs to good tension
http://forums.pelicanparts.com/uploa...1375576773.jpg
Top view
http://forums.pelicanparts.com/uploa...1375576991.jpg
Discseven 08-03-2013 07:03 PM
Aloha Hemmah,
I've been thinking about diving into my shifter... your post has pushed me over the edge! So I have to ask... why did you dig into this? What's to replace in that area?
hemmah 08-03-2013 07:24 PM
Aloha Discseven,
My adventure into the shifter was a mistake. I bought a replacement bushing pack and started taking stuff apart.
I got it all together again with new bushings. Works good.
Don't take the springs out of your shifter.
Walt Fricke 08-03-2013 08:49 PM
Sounds like a commercial: don't take the springs out of your shifter, or you'll end up in a roadside ditch (or selling your hair for wigs)!
Shortening a spring makes the spring stiffer. Guys who lowered their cars by cutting a coil found that piece of engineering fact out the hard way.
So have you noticed that you have to push harder when shifting to get to where you want to go? That's not necessarily a bad thing. You used to be able to, and may still be able to, buy stiffer springs for this application. Came, as I recall, with a warning that they were tough to install. But you cut quite a lot off, so it should be quite a bit stiffer.
And can we assume that you can get to all of the shift planes? You don't run into coil bind when going for the side where the springs are most compressed?
hemmah 08-07-2013 08:29 AM
Walt,
Yep the shift spring experience has been a bad commercial.
I did think about the spring stiffness and binding when I engineered the solution. The stiffness is set by how much I tighten down the inside bolts. So it is adjustable as the original was not but optimal to Porsche Engineering. I tightened until the springs just started to bend - similar to what was original. So no binding.
Bottom line the shift springs work as they did before - feels the same spring wise. The bushing are replaced. The commercial is a happy one now.
Take care,
Discseven 08-07-2013 08:39 AM
Thanks for the reply Steve! Got it on the "Don't take the springs out!"
... does sound like a commercial!
tobluforu 08-07-2013 08:44 AM
I remember doing this 20 years ago, got damn springs shooting accross the living room, swearing, etc..
hemmah 08-07-2013 04:47 PM
Yes the springs shot across the room. Swearing was involved. Even more swearing trying to put them back in.
19-911-65 08-07-2013 06:18 PM
I just rebuilt my shifter last week. The first spring removed...I caught with my chest...;-)...the second removed we placed a rag over it.
Placed in a vise, cleaned all the parts and inserted one end of the spring against the plate, driver's side (over the end of the pin pushed through about a 1/4") and "bowed" the spring upward in the middle and then pushed/worked the other end in place.
I would rate it as a one beer job.
Glenn
http://forums.pelicanparts.com/uploa...1375927999.jpg
http://forums.pelicanparts.com/uploa...1375928029.jpg
http://forums.pelicanparts.com/uploa...1375928066.jpg
http://forums.pelicanparts.com/uploa...1375928173.jpg
Classic 08-07-2013 08:52 PM
And old screw driver with an appropriate slot cut into it does the trick for the re install, about 5 minutes.
