-   -   930 3.4 Oil Pressure Relief Valve - WTF? - With Videos (http://forums.pelicanparts.com/porsche-911-technical-forum/764385-930-3-4-oil-pressure-relief-valve-wtf-videos.html)
DSM 08-05-2013 04:31 AM
Can someone explain why the washers and the small steel ball came out of my oil pressure relief valve? It fell out when removed. I assume this is how it was assembled inside. The washers fit inside the piston and match the spring dia. They will not fit over the spring guide. No clue on the steel ball?
http://forums.pelicanparts.com/uploa...1375702132.jpg
I'm looking for a solution to low oil pressure at full warm up idle. The pressure is just under 1 bar @ 1000 rpm. On cold start pressure is 4+ bar. As it warms up pressure drops. Ok, that's normal but the knocking noise at idle when its fully warmed can't be normal?? Check out these videos. One is after a few minutes of warm-up and the other is after full warm up. Once its warmed up the noise is only heard if oil pressure is 1 bar or less??
http://s403.photobucket.com/user/supersport911/media/BEFOREFULLWARM-UP_zps108925e9.mp4.html
http://s403.photobucket.com/user/supersport911/media/AFTERFULLWARM-UP_zps0fc07968.mp4.html
ManniB 08-05-2013 04:49 AM
Hi,
the shims are the trial of a previous owner to increase the oil pressure. Shimming the spring effectively increases the spring rate which increases the pressure at which the valve opens. However, I have no explanation for the small steel ball???
A little below 1 bar oil pressure at 1000 rpm sounds normal. You do not mention the warm oil pressure while driving. It should be approx. 1 bar per 1000 rpm.
- Manfred
kodioneill 08-05-2013 05:44 AM
I have no idea what that ball is doing in there I would not put it back. 1 bar at warm idle is normal 15 psi. As far as the washes go I wouldn't put them in either if you do install them under the spring in the cap.
chrisbruck 08-05-2013 09:17 AM
Have fun putting it back together.... mine was a PITA while trying to reinstall from underneath the car. Can't tell you how many times that spring launched the plug out of my oily, slippery fingers.
DSM 08-06-2013 04:27 PM
- Manfred
The pressure while driving is normal. Approx. 1 bar per 1000 rpm. Its the noise that concerns me. When pressure is over 1 bar no noise at all?
Any idea what the noise could be? Intermediate shaft? Could it be normal? I've heard other modified 930's sound like this at idle.
Thanks!
kodioneill 08-06-2013 04:55 PM
Originally Posted by DSM (Post 7588377)
- Manfred
Thanks!
JAR0023 08-06-2013 04:57 PM
Porsche's answer to low oil pressure at idle was cam oil line restrictors. I don't know enough to recommend them or not. The pros seem to be split on yes or no. If you stroll over to the engine rebuilding forum here and search you will find a ton of info. -J
304065 08-06-2013 05:47 PM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/712724-ultimate-oil-pressure-relief-valve-thread.html
fastfredracing 08-06-2013 05:59 PM
That little ball looks like part of the check valve on pressure fed chain tensioners. Maybe worth a look.
DSM 08-06-2013 07:11 PM
Interesting?
Chain Tensioner Repair Kit:
http://forums.pelicanparts.com/uploa...1375840822.jpg
911 Timing Chain Tensioner Malfunction Article:
http://forums.pelicanparts.com/uploa...1375841337.jpg
kodioneill 08-07-2013 04:51 AM
Originally Posted by DSM (Post 7588616)
Interesting?
Wow good catch! Do you think that ball is from the chain tensioner? Could be.
kugelfischer 08-07-2013 07:21 AM
First thing to do it is to confirm your actual oil pressure using a mechanical guage, not the dash guage. As you know, the dash guage is notoriously inaccurate. Additionally, it's possible that your pressure sender has gone bad.
Next would be to address the knocking sounds. There can be MANY possible sources, but to be honest, I wouldn't Plano driving the car much until you get this sorted out. Many of the sources are potentially damaging to the engine.
Well, maybe not in that order but I'd do both before running the car too much at this point.
MBruns 08-07-2013 09:45 AM
Ball
The washers are a common item to boost the oil pressure, the ball however could be the wrong size installed in the turbo feed check ball assembly on the top side of the case (which falls right straight down) to the assembly you have laid out.
Mike Bruns
DSM 08-08-2013 04:28 AM
That makes sense. The turbo oil feed line kit is from Turbo Craft. I didn't install it so can't explain this at the moment. The ball diameter in the picture is 4mm. Is this the correct size. I will contact Turbo Craft when I get a chance.
Thanks all!
MBruns 08-08-2013 05:52 AM
ball
The factory check ball is 9mm, the part # is 900-108-022-00
Mike Bruns
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
