-   -   ITB Sizing (http://forums.pelicanparts.com/porsche-911-technical-forum/764494-itb-sizing.html)
Tom Oxner 08-05-2013 04:29 PM
ITB Sizing
Is the rule of thumb for ITB sizing the same as for carbs? The 40 MM carbs have a venturi which provides some restriction. I am trying to determine what size ITB I should use on a stock 3.0 euro motor. Thanks for your help.
Tom
brads911sc 08-05-2013 04:39 PM
40 will be good. I have a 3.2SS and I use 40s. I was told by several pros that they are good and that I'm not leaving anything on the table. In fact most told me that 46 will be too big.
roblav 08-05-2013 06:31 PM
Use the intake port diameter.
Tom Oxner 08-05-2013 06:46 PM
I think the intake port size on the "big" port SC heads is 39MM. If that is the case, then the 40MM ITB would be about the correct size. Thanks,
Tom
al lkosmal 08-05-2013 07:11 PM
Tom,
Here's some reference info.
Tuning ITBs - 77e21.info
regards,
Al
roblav 08-05-2013 08:41 PM
I just went through this and decided on 42mm Suzuki GSX-R750 throttle bodies for fabrication on my 3.2 engine. 40mm intake port. Close enough and leaving a bit of (small) room for expansion!
al lkosmal 08-05-2013 10:24 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/741911-d-zug-tours-rsr-dyno.html#post7547875
Here's a link to the Dzug RSR project. Justin and the crew have just installed my Speed Triple EFI/ITB kit and if you scroll down the thread a bit you will see the drive by.
This RSR has a 3.2SS, formerly using CIS...now with the ITB's installed. They are 42mm. The sound that the RSR makes as it goes by is.........excellent. They are headed to the dyno shortly.
regards,
Al
