-   -   Some help identifying wires in the Main cab harness of a 84 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/764504-some-help-identifying-wires-main-cab-harness-84-911-a.html)
cabmandone 08-05-2013 05:33 PM
So the 75 donor car I bought had the harness for the 3.2L in it sort of. The 84 911 Cab didn't. The problem is, the harness from the donor has a long black tail that is forward of the Motronic and other items under the driver side seat. The long tail has one Red wire, one Red wire with green stripe, one yellow wire, one Green Wire with yellow stripe, one black wire with blue stripe and 3 black wires. None of the wires have an end on them as they have been cut. . Any help on where these wires go and what they do would be very much appreciated.
I will be attaching a picture of the harness for a reference of the wires I need help identifying.
Anyone nearby wanting to come over and help, there's a homebrew beer or 3 in it for ya.
Discseven 08-05-2013 07:49 PM
Photo would help CAB!
cabmandone 08-06-2013 03:52 AM
The wires I'm trying to identify are In the long loom that appears to go up to the trunk area. I now know the Red/green wire goes to the fuse panel at the fuel pump fuse which is the 6th fuse from the left as you look at the panel.
http://forums.pelicanparts.com/uploa...1375786104.jpg
