Q to BBS-wheel experts!
Does anyone know how im supposed to seal the seam beetween outer and inner part of the wheel (those 3-pieces)?
should there be somekind of o-ring or silicone or what, all i know that my "installation glue" does not work...
Kristian
911T -70
Old 08-03-2002, 02:44 AM
Navin Johnson
TimT's Avatar
After you bolt the three pieces together, run a bead of silicone around the seam, Let it cure then mount your tires
'69 911 GT-5
'75 914 GT-3
and others
Old 08-03-2002, 04:32 AM
ok, but isnt it hard to put that silicone there when the tire is installed on wheel, i cant install tire after wheel is bolted together can I?
kristian
911T -70
Old 08-04-2002, 11:24 AM
