Dash Lights Stay On
Went to start the car this weekend and the battery was dead. Figuring a light was left on, I recharged the battery it started easily. Found that the dash lights including the green light on the speedo stay on, regardless whether the ignition switch is on or off or what position the light switch is in. Also, my fog knob light switch stays lit when depressed with the ignition off and turns on when the ignition switch is in the on position.
Checked all of the fuses and screw connectors on the fuse wires and all were good. They only new work, was replacing a damaged door speaker. This required removing the window switches, but I tagged the wires, they worked when reassembled and I just pulled them tonight, but nothing changed.
Any suggestions? Check for a loose/lost ground (where)? Check/replace the light switch? Check the ignition switch? Any suggestions on where to look?
'84 Carrera
3.4 twin plug
Old 08-06-2013, 07:51 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Search for 86 911 Targa, Dr Gerry has a diagram aof the light switch wiring, something is crossed.With headlight switch pulled out, your fog light switch will iilluminate.
'85 Carrera Targa
PCA/POC
Old 08-06-2013, 09:42 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
From our '86:
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-08-2013, 05:22 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
