-   -   Does a MSD fit into Marelli Distributor. (http://forums.pelicanparts.com/porsche-911-technical-forum/764811-does-msd-fit-into-marelli-distributor.html)
Tweedle 08-07-2013 05:29 PM
Hopoing to up grade to non points (MSD system) for my ageing Marelli Distributor. Anybody do this, is it worth while?
Bob Kontak 08-07-2013 05:32 PM
You have a 69 911T, correct? Folks need to know that.
mcaterino 08-07-2013 06:23 PM
You can run your Marelli (new rotor, cap, and points are now all available, so its aging isn't a terminal problem) with MSD, keeping your points. Some folks change the points to an optical trigger, and maybe that's what you're thinking, but it's not necessary. I'm quite happy with the Marelli, points, and MSD setup. Pretty simple.
Mike
Tweedle 08-07-2013 09:28 PM
That's right 69T, so how does the MSD set-up work?
mcaterino 08-08-2013 07:58 AM
Tweedle,
If you search the forum for 'MSD Marelli' you'll have pages of information at your fingertips. Here's one for starters:
http://forums.pelicanparts.com/porsche-911-technical-forum/635427-msd6a-marelli-1971-911t-dummies.html
(and I don't mean anything by that, that's just the thread title). It's not really clear what it is you want to accomplish.
Mike
