Can I set the cam timing,without using the dial indicator gauge ?let me know,please.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
You can but there is a very good chance you will be slightly off regarding the valve timing.
- Kerry |
I do not see how you could get the cam timing even close without a dial indicator. The dial blog and indicator is a cheap tool given the danger and consequences if you get it wrong. Even with the dial indicator it still took me a hour to get it correct
Not recommended for sure...
You set cam timing in two places. Both sides will be a far ways away from being correct and the two sides will not match each other. |
just use your eyecrometer
If one is asking that question, I would wonder how much one actually knows about what one is doing? Are you also torquing without a torque wrench?
Of all the special tools needed, the Z block/dial gauge is probably one of the cheapest to DIY. Do a little searching. Dial gauges are cheap at places like harbor freight. There are a number of low tech, low budget Z blocks in several threads here. Bet you could put one together for less than $25.
Z block is unavailable here, can you point me to where I may be able to find/build a set of tools to do the cam timing? It's the one thing (so far) I haven't done myself.. Just need a Z Block and dial indicator?
Red fan haters aside...
Here's the post that has dimensions and pictures of the low tech, highly functional DIY Z blocks I mentioned. Here are a couple other Pelican Parts threads on the same topic: http://forums.pelicanparts.com/porsche-911-technical-forum/758452-z-block-alternative.html http://forums.pelicanparts.com/porsche-911-technical-forum/466087-z-block-dial-gauge-holder-cam-timing.html http://forums.pelicanparts.com/911-engine-rebuilding-forum/743652-z-block.html |
I sent the dimensions to a CNC buddy, lets see what he comes up with. Are all dial indicators the same diameter shaft (.375)?
9.52mm or ~3/8" = standard stem size so .375 will fit nicely with a thumb screw to secure at the stem.
| All times are GMT -8. The time now is 08:35 AM. |
