-   -   should I use the '85-'89 911 or the Turbo CV's for best strength. (http://forums.pelicanparts.com/porsche-911-technical-forum/765372-should-i-use-85-89-911-turbo-cvs-best-strength.html)
Jim (guest) 08-10-2013 10:41 PM
Hello, I have a build going that will use a '76 930 transaxle to a modified Corvette C5 hub 930 pattern. Since I must spec axles regardless, I'd like to know if I should use the '85-'89 911 or the Turbo CV's for best strength. It looks like only the width changes. Thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 08-10-2013 10:41 PM
The turbo axles would be the stronger design
- Kerry
