-   -   WHEN I PRESS THE HORN I ONLY GET A CLICKING? (http://forums.pelicanparts.com/porsche-911-technical-forum/765392-when-i-press-horn-i-only-get-clicking.html)
rick (guest) 08-11-2013 01:12 AM
WHEN I PRESS THE HORN I ONLY GET A CLICKING ,,,ANY HELP WOULD BE THANKFULL ,,RICK
This post was auto-generated based upon a question asked on our tech article page here:
Kerry at Pelican Parts 08-11-2013 01:12 AM
Where is the clicking coming from? If it's coming from a relay you may have a blow fuse, bad horn or broken wiring. Jump the horn relay and see if it sounds
- Kerry
DRACO A5OG 08-11-2013 11:54 AM
The horns sits in a very harsh environment, check to see if the connectors are loose or worse corroded away.
+1 click is from the relay in the fuse panel.
