Speedo output "A"
Hi,
while trying to track down the problem that keeps the cruise control of my '80 SC from working I found that the signal "A" from the speedometer to the cruise control brain (and the OXS milage counter) looks odd. Actually, the doesn't seem to be a meaningful signal. http://forums.pelicanparts.com/uploa...1376232722.jpg Before I finally conclude that the speedo is shot, I would like to ask the following: - What is the output configuration of "A"? is it a relay contact, a transistor, or what? - How would a valid signal look like? I assume it would be some kind of frequency related to how fast the wheels turn. Is it a voltage (rectangular between 0 and 12 V)? - Any other idea how I can check the "A" signal? The speedometer is a VDO model 437.201/1/20 Thank you, Manfred |
Manfred, I can't answer your question because my car is in the shop and I can't stick a scope on the A terminal. However, I never realised the A terminal was output for the OXS sensor - so you've explained why I've never had to reset mine in 30,000 miles (it's not connected)...
I'd expect it would have a good chance of being a 5V square wave output though - that's what you get from the transmission sensor. |
Bump...
I can't believe that no one has an answer for me SmileWavy |
| All times are GMT -8. The time now is 06:49 AM. |
