goldgunner's Avatar
Smuggler's Box - GASKET
Anyone have a source for the trunk A/C - aka Smuggler's Box - gasket?
My new A/C system, and especially the new evaporator, needs a nice tight enclosure.
Pelican just back orders on the gasket. I've been unable to find anywhere to buy new...
So - Sources, please?
Or, lacking that - successful work-arounds / use insteads?
Thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 04-26-2006, 04:13 PM
Jim,
Try a dealer. I've bought one recently with no problem. Surely I didn't get the last one. Part number 911.504.491.02
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 04-26-2006, 04:35 PM
Make Bruins Great Again
Por_sha911's Avatar
Thinking outside the box (pardon the pun):if you can't find a factory gasket, maybe a rope gasket (like the kind used for a wood stove door) would make a good seal. It could be cut to any length.
Joe
Old 04-26-2006, 06:08 PM
Zeke's Avatar
Also, there is a adhesive backed foam weatherstripping at home and hardware stores. Some of it is pretty good. Might be resistant to tight radii, though. Could get you by until you find the factory stuff.
Old 04-26-2006, 06:21 PM
Formerly bb80sc
Vipergrün's Avatar
If I did not toss my gasket with the removal of the lid...you can have it...let me look for it.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-29-2006, 12:57 AM
Jastx's Avatar
Your evaporator housing provides all the sealing for your A/C system. It sucks in air from the passenger compartment through the intakes in the passenger footwell and driver footwell, pulls it through the evaporator and pushes it into the dash ductwork.
The smugglers box is open to the outside through the bottom of the car -- that's where the A/C hoses run. A perfect seal on the cover won't do anything to keep out outside air.
The foam that seals the mating of the evaporator housing to the footwells deteriorates over time and can let in warm outside air. You can remove the passenter air intake and redo it. The round driver footwell foam can't be accessed unless you pull the evaporator housing -- which you can't do unless you disconnect the A/C hoses.
John
2005 997 Carrera S -- Artic Silver/Sea Blue
Former friends: 1989 930 factory Slantnose /
1998 C4S Coupe / 1973.5 911T / 1976 914 2.0
Old 04-29-2006, 08:09 AM
So can anyone tell me what the dimensions of that round foam gasket is that seals to the footwells is or a picture of a good one on an evap box. I made up a gasket out of back pack foam (after making it thinner) and the box doesn't quite fit now. I guess I could remove and split the box again and view the actual gap between the box and the footwell tube. It seems kind of funky to just have the tube and box butt up against each other if the foam is thin.
Thanks, Gary
Old 08-12-2013, 09:49 PM
Ah, found the answer @ "81 sc evaporator box ports" thread.
Pelican is best for the DIY Porsche.
Gary
Old 08-12-2013, 10:00 PM
