915 transmission
I'm trying to figure out some shipping details.
What does a 915 weigh ? Thanks, WP |
83 911 Production Cab #10
In the short term, about 110 pounds
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Some knowledgeable guys on the board recommend shipping a transaxle in a large plastic cooler through Fedex. 120 bucks cross country.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
I second that. Drill some holes around the edge and use plastic wire ties to bound lid. Then just pack it with preferred "stuffing". Lighter, quicker and cheaper than making a wood crate. And when done its either useful or easier to dispose of than a wood box.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Thank you for the information ..................
Pretty sure my 915/73 with LSD was a lot more than 110 lbs packed. Seem to recall my G50 was around 160.
+1 on the cooler; cheap, effective and easy. You MUST drain the transmission oil, otherwise not only is it a godawful mess inside when it leaks out the breather, you probably risk the carrier dumping it half-way and refusing.
'77 S with '78 930 power and a few other things. |
Grand Am/IMSA Data Guy
I use the next to largest cooler at Walmart (measure and I think you need 31 in length and 14 or 15 width and height. Coleman Xtreme 120 Quart Cooler - Walmart.com
A complete trans and the cooler weighs 144 pounds and FedEx will ship up to 150. I get a reduce rate and it is about $110, retail might be about 130 bucks. I think this is the best way to ship. I usually screw the lid closed with some sheetrock screws
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
