Exclamation Need Advice !
Finally got most of the parts to reconstruct a 78 911 that was hit in the passenger side front... I need a good and reasonable frame shop... I have the clip to replace the damage. Should I get it straightened and then put the clip in, (from the front shocks forward), or just get it straightened and put it back together? All advice is appreciated... I am located in Baltimore, MD and would be willing to travel up and down route 95, 50 miles each way or a 50 mile radius of Baltimore, MD.
Thanks in advance...
Nestor J. Velazquez
Navy Veteran
Old 08-13-2013, 07:22 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Look up porsche962 in the paint and bodywork forum and PM him. He has a shop up your way. He is top notch.
1981 911SC Targa
Old 08-13-2013, 07:28 PM
Will do ! Thx !
Old 08-14-2013, 06:10 AM
Advice.
Nestor, regardless if you just get the car straighten/aligned or you will have the front clip installed, make sure that the shop that does the work has a Jig bench. Two makers are approved by Porsche; Car-Bench and Celette. You can only get the job done correctly and square on a Jig bench.
Good luck and post pics.
Bill.
Old 08-14-2013, 05:04 PM
