-   -   Your must haves for a 3.2 build! (http://forums.pelicanparts.com/porsche-911-technical-forum/766082-your-must-haves-3-2-build.html)
Fubawu 08-14-2013 07:59 PM
Hi
A friend and I are just starting a build on a 3.2 for my 71. I believe the current
motor has issues with one or more of the con rods. Either way what would
be on your list of must haves. Parts ,specs brands etc. I currently have freshly rebuilt Zenith's 40 for it with MSD ignition. I thought it would be nice to get some advice/input from those in the know. I was planning a mild rebuild but if it's open why not give it a little more attention. Thanks for any input.
Cheers
John
jager911 08-14-2013 08:37 PM
What's your budget and intended use? You could do cams, ARP rod bolts, hi-compression pistons, twin-plug, ported heads, flowed intake etc etc if money's no object.
On a budget, maybe cams, headers (if heat is not needed), M&K muffler and tuned Motronic, I wouldn't put carbs on my 3.2, too much tuning needed.
Do a search, it's all been done before.
Koizumi 08-14-2013 10:04 PM
Supertec studs: no more worries.
Uncle 08-14-2013 10:24 PM
Scotch.
Geronimo '74 08-15-2013 12:35 AM
Supertec headstuds, arp rodbolts, 964 cams, new (sporty) valve springs, Ti retainers....
Fubawu 08-15-2013 04:10 AM
Thanks for the input guys, I also have European Headers and exhaust. The Carbs were already on the car so I am going to stick with it. I am in the process of trying to get 964 rsa cams.
bike2ride95 08-15-2013 04:34 PM
Twin plugged set up..i have a kit just removed set up for 3.2 case.
twin dizzy, plug wires w/ MSD. Drill the heads on your case, plug
and play..:D
