ejp ejp is offline
ejp's Avatar
Door seal/weatherstripping question
I replaced my door seals today. It was a pretty quick job. However, the door requires a bit harder of a slam than it used to before. Further, upon opening, the doors kind of spring open a little (as there is pressure from the new seal).
Do these typically settle in after a few days, or did I screw up?
-Ethan
Old 08-10-2013, 11:42 AM
Door seals
Seals are made of EPDM sponge (synthetic rubber) and definitely take a set over time, especially if exposed to high temperatures. If your old ones were more than 10 years old, and you live anywhere south of the Mason-Dixon Line, they could have compressed up to 40% or more.
Old 08-10-2013, 11:54 AM
ejp ejp is offline
ejp's Avatar
Thanks, Lyle. I'll let it sit for a few days before I muck about with trying to re-apply.
-Ethan
Old 08-10-2013, 12:05 PM
docrodg's Avatar
New seals could require you adjust the latch a little bit. They shrink so much over time.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 08-10-2013, 05:31 PM
Hendog's Avatar
Yep, I did this last year and got the same results The "spring" doesn't go away in a few days or weeks; it lessens a little over a year.
Now I can drive it in the rain and stay dry inside
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 08-10-2013, 09:06 PM
ejp ejp is offline
ejp's Avatar
It's been nearly a week, and the doors aren't getting any easier to close. I feel that I may need to adjust the latches.
Any tips on adjusting the door latches/strike plates? I just ordered a set of triple square sockets from Amazon, which should arrive tomorrow. However, I have not found any documentation for adjusting these. Is it just a matter of loosening those triple-square bolts and moving the plate - or will I need to get in from behind the body panel?
-Ethan
Old 08-15-2013, 01:45 PM
AutoBahned
RWebb's Avatar
you can work on cleaning the crud away while you wait for the sockets to arrive - hose the fasteners down with kroil for a few days too - & tap on them a few hundred times
Old 08-15-2013, 01:59 PM
Jp-oh's Avatar
Quote de docrodg
Just loosen them at the striker. I just adjusted my drivers door and it was dead easy. Don't loosen them much, just enough to move them. The adjustments needed are really really small; a little goes a long way.
Old 08-15-2013, 03:53 PM
ejp ejp is offline
ejp's Avatar
Will soak them down.
It turns out that the bits that I bought are not socket, but for a driver, which is might be OK. They will fit nicely into the impact hammer that I use for the rear brake rotors. Do you think that an impact hammer will work or damage the body?
-Ethan
Old 08-15-2013, 10:16 PM
AutoBahned
RWebb's Avatar
you are going to remove the wheel and reach back in behind the pillar - unless you miss a hand impact tool will be perfect for the task
be sure to clean the wrenching fixture out very carefully with a metal pick tool
also see if you need to treat rust, add undercoating etc. while in there
clean the taillight housing area also & remove the 10 lbs. of gravel you find there
Old 08-16-2013, 12:45 PM
There are two screw heads that hold each striker plate. They are accessible from the door side of the B pillar. Your 8mm triple square should work with a 1/2 socket and you should be able to use your 3/4" ratchet. I had the same experience. The new seals take a long time to crush and stay somewhat crushed.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 08-16-2013, 01:31 PM
