High Beams quit working
I seem to have a problem with my 1985 ROW Carrera high beam headlights. Fuse for each looks good. Little blue light comes on when switch is pushed and low beams go off, but no high beams. It gets dark and scary out away from city lights.
Possible bulbs need to be replaced? Any flickering or a flare before they stopped working?
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
The switch for the Beams is known for being bad. When mine was broken, the low beams were all i could get outta the high beams. There is someway that you can bybass the switch and test the switch but i'm not sure how to.
1980 Porsche 911SC |
No flicker or flare, just did not come on. I will check the bulbs before I tear into the switch.
Been here a while
Mine was a bad high/low beam switch that is part of the turn signal switch, was able to disassemble and free up a stuck reed switch
looking for 1972 911t motor XR584, S/N 6121622 |
I figure if you can flip the switch to high beams and get the blue indicator to illuminate then the switch is fine. I always like to check the simplest fix before digging in. My money's still on the bulbs.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
+1 on the hi/lo switch, mine was so bad and gunky it went up in smoke and got stuck, just replaced the whole thing....
Dietmar 1987 911 Carrera 2008 RS 60 Spyder |
You didn't mention if the high beams work if you pull the switch towards you. If memory serves those are two different contacts. My highs only worked if I pulled the switch towards me (i.e. flashing them), but didn't work if I pushed the switch away from me.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
No, it does not work in either position. Now I have a new problem to go with the high beam glitch. The wiper switch is not working either. Do these two switches have a common ground?
Not sure about the ground. Each switch has a socket type harness connector that goes into the firewall under the dash. Is it possible that both of these are loose? You can push on them to make sure they each have a solid connection. Worth a shot at least.
