Southern Class & Sass
Dixie's Avatar
Help: Valve cover stuck
Why the heck can't I get the upper passenger side valve cover off? I don't recall ever having this problem before. I have all six nuts off. It won't budge! Do I have to remove the A/C bracket? I don't remember having to do that.
g]
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 08-17-2013, 01:05 PM
6 cylinder symphony
No - A/C bracket does not have to come off.
Sounds like it's just grunged on. Hit it with some penetrating oil around the gasket area, and gently tap it with a soft hammer, while wiggling it if you can.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 08-17-2013, 01:12 PM
kodioneill's Avatar
Looks like some corrosion on the studs rap it with a plastic hammer or a wood block.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 08-17-2013, 01:45 PM
Dixie's Avatar
Finally! It's off! It was simply a bit glued down to the gasket.
I'll pick up with the valve adjustment tomorrow. I've learned that when you start getting mad, you need to put the project aside for a bit.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 08-17-2013, 02:17 PM
kodioneill's Avatar
You can't get mad at these cars they're a little finicky but so much fun when you win.
1982 chiffon 911sc
Old 08-17-2013, 02:20 PM
