dazed and confused
john baldwin's Avatar
Main Seal
Hi all,
Attacking various leaks...pulled the flywheel to find this. Does this look OK or is the main seal on it's way out? Have seen much worse pics on this forum...would rather not have to replace it if I can.
Appreciate any feedback.
John
89 Carrera 3.2 Targa
2011 BMW 335d
2013 BMW X3 3.5
80 911 SC Weissach Coupe (Sold)
Old 08-17-2013, 12:51 PM
Your photo isn't sharp enough for me to tell conclusively, but if its not damp or wet around the perimeter of the seal, its OK.
I would replace the oil pressure sender, thermostat O-ring, and breather gasket to prevent oil leaks contaminating the clutch disc. Thats SOP for any clutch job.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-17-2013, 01:19 PM
E Sully's Avatar
It doesn't look bad. I am a little excessive and always fall for the while your in there stuff myself. The first time I changed it on mine it did leak a bit, so the second time I did not set it as deep, leaving it slightly proud of the lip and it sealed well. Clean off the other seals and put some JB weld over them.
Ed
1973.5 T
Old 08-17-2013, 01:24 PM
dazed and confused
Thanks, Steve.
Dry around the perimeter of the seal..all the seals you mentioned are lined up and ready to go in!
Ed,
I too am a "while you're in there" type of guy, but from what I've read it can be tricky to get this one right...I think I'll leave it alone...plenty else to do!
j
2011 BMW 335d
2013 BMW X3 3.5
Old 08-17-2013, 02:04 PM
Originally Posted by john baldwin View Post
Thanks, Steve.
Good man!!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-17-2013, 02:07 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by Steve@Rennsport View Post
I would replace ........... breather gasket to prevent oil leaks contaminating the clutch disc. Thats SOP for any clutch job.
Regarding this gasket, is it sacrilege (or just wrong) to put some gasket goop (Permatex #2?) on given the double downside of it leaking onto the clutch disc and the time to replace it if is leaking?
1981 911SC Targa
Old 08-17-2013, 03:13 PM
I never use any sealant of any kind on that one.
I've seen far too many ruined engines due to excessive use of such products.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-18-2013, 12:23 AM
Bob Kontak's Avatar
Thanks - enough said.
1981 911SC Targa
Old 08-18-2013, 12:42 PM
