Any way to stop peeling paint.....
Got my 912E today - nice car - bad paint.
Typical 1976 fault - peeling paint. I dont want to repaint the car now - just stop the peeling and touch up the bare spots.
Any ideas to stop the peeling?
Cheers,
Christian
Old 08-28-2013, 04:30 AM
twistoffat's Avatar
ThereŽs no silver bullet unfortunately. All you can do is treat the bad spots until you decide on a date for a respray. IŽd just sand the spot and around it until you have something you can work with. Get a can of matching paint and touch it up so its protected. A bit of wet sanding and polish might help iron out the colour differences somewhat but if the peeling is bad and rust a cars worst enemy IŽd think about getting it done sooner than later
Old 08-28-2013, 05:23 AM
Thanks a lot. Will try that. The surface is clean and "zincy" - no rust. I just dont want to peel away untill there is no more paint on the car
Old 08-28-2013, 05:30 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Could you get one of those matching color finger nail polish touch up bottles and "glue" the peeling? Don'know the extent.
Did not know peeling was a common problem. First year with full zinc hot dip though, right?
1981 911SC Targa
Old 08-28-2013, 06:29 AM
Fb = M/S
aoncurly's Avatar
I would definitely "feed" your remaining paint as well to help abate more peeling. Paint loses oils over time and exposure and you get cracking as the paint becomes brittle. Replace the lost oils with an appropriate polish.
Old 08-28-2013, 09:37 AM
sandpaper :-P
Speeds just a question of money, how fast do you wanna go?
Old 08-28-2013, 05:16 PM
Morrie's Avatar
My 912E was the same way. I was told at one point that the factory galvenizing process was done overkill, and that somehow prevented the paint from sticking well over time. Mine sat out in the rain with bare metal exposed and did not rust... stayed gray and chalky. Crazy.
At repaint time, what needs to be done to insure this doesnt happen with the new paint?
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 08-28-2013, 06:41 PM
