Flywheel
Can somebody confirm what years used the flywheel part 930.102.233.3R.
I found mixed results some say g50 (87- 89) others 915 (84-86). I have the sachs clutch and spring plate for the 915. Will this work with that flywheel and which starter ring do I get 84-86 or 87-89? Thanks Martijn
'66 3.2 "Blue Car" '73 3.0 "Orange Car" '78 3.2 "Brown Car" |
i'd search that part no. on host site.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
It's a casting nr that pp doesn't list.
I just would like to know which of the parts are interchangeable between 915 and g50. Flywheel ,clutch ,pressure plate and starter ring. I found this thread but it doesn't specify which clutch and starter ring is used and the casting is a ...0r This Flywheel for a 915 or a G50? Last edited by tijnes; 08-20-2013 at 05:28 AM.. |
Fleabit peanut monkey
Use this page and open up the parts catalogs for each of the models you are trying to compare.
The flywheel is in the engine section and the disc, plate and ring are in the transmission section. I could not find matching numbers between the 915 and G50. Porsche Classic Genuine Parts Catalogue - Classic Genuine Parts & Literature - Porsche Classic - Dr. Ing. h.c. F. Porsche AG
1981 911SC Targa |
915 to 83 is flat, 84-86 is cupped, 87-89 is stepped.
So what I have is a 87-89 flywheel. Can I use this with a 915 Sachs clutch and pressure plate? I assembled it and it fits just fine. Doesn't mean that it ll work
It's flat on the inside with a track cut out as you can see. It had a Sachs disc.
ASE Master Tech - 35 yrs
from my '89 3.2 with g50
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
