-   -   Engine and transmission mating (http://forums.pelicanparts.com/porsche-911-technical-forum/767490-engine-transmission-mating.html)
sojahseh 08-23-2013 07:35 AM
I inadvertently posted this in the engine rebuilding forum. In this forum is probably more appropriate.
I'm at the point where I'm ready to put the drivetrain back in my 85 Carrera. I have the transmission and engine sitting on separate pallets. I have already installed the exhaust system on the motor, but from the look of it, it would appear that the crossover pipe will get in the way of the clutch arm if I try and mate the transmission to the engine.
Is this an optical illusion? Does the exhaust have to be off the motor to install the transmission?
Thanks in advance...
Smoove1010 08-23-2013 08:00 AM
My 87 has the G50 instead of the 915, but I don't think they differ in this regard. I mated my trans to the engine with the exhaust in place. Here's the spot in my project thread where I did so - the pictures might help you out.
http://forums.pelicanparts.com/porsche-911-technical-forum/729856-87-drop-top-drop-n-top-end-3.html#post7480668
Good luck,
GK
Roger 911 08-23-2013 08:39 AM
You should be able to mate the engine to tranny with the exhaust in place. I just did this with a '84 engine and tranny. It took some careful jockeying to get everything to mate properly, but it did.
Roger
yelcab1 08-23-2013 08:41 AM
If it is a problem, you can just remove the cross over pipe and install it later. The G50 tranny does not have a clutch arm protruding at the bottom so it does not have the same issue.
Roger 911 08-23-2013 08:48 AM
...or remove the clutch arm. I believe that is held on with a circlip. Now that I think about it, I don't think I had the clutch arm on the tranny when I mated it to the engine. I think I just attached the arm after the engine/tranny were back in the car.
Pazuzu 08-23-2013 09:03 AM
Remove the arm, you don't want any spring tension on the fork when you're trying to get it to mate with the throw out bearing. If the arm/omega spring is in place, you'll never get them together.
It's also a good change to clean up/derust/grease the whole exposed assembly under there.
