-   -   Continuous popping while idling - lean ? rich ? (http://forums.pelicanparts.com/porsche-911-technical-forum/767532-continuous-popping-while-idling-lean-rich.html)
prebordao 08-23-2013 12:33 PM
I'm having trouble adjusting the mix / pressures:
Latest symptom: while idling and stopped there's a continuous popping from the exhaust... Indicates rich or lean condition ?
Car was not fully warmed yet.
kodioneill 08-23-2013 12:51 PM
Year/model/miles?
prebordao 08-23-2013 01:02 PM
1974/S/many
Bob Kontak 08-23-2013 01:04 PM
Is it a popping or "puffing" backfire? I had puffing which was like a mini backfire but not noisy when I had an air leak at the base of one of my intake runners. Happened all the time.
prebordao 08-23-2013 01:11 PM
It's really a pop-pop-pop similar to the small backfires you can have when your decel valve is not connected and you lift suddenly. But here it was continuous.
Bob Kontak 08-23-2013 02:05 PM
Before I start rambling, did this symptom start after you made some adjustments to pressure and mixture?
prebordao 08-23-2013 02:26 PM
Yes, after.
But now I know its rich. The wur heating element isnt working so it takes a lot of time to reach oper temperature, so mix remains too rich too long.
Back to the gauges again.
Bob Kontak 08-23-2013 02:38 PM
Try a hair dryer on it to warm it up quicker. just a thought.
docrodg 08-23-2013 03:12 PM
Double check timing too. A retarded timing can cause a small amount of the pop as well but be hard to detect at high rpm. Reason is fuel burn not complete when exhaust opens giving a pop or huff.
prebordao 08-23-2013 03:33 PM
I have the grandaddy of WURs - the 001
I just opened it and it's a bit different inside from the newer ones.
Later I'll post pics and a probable explanation.
This one has an additional resistance inside that seems to cut power to the element when it heats...
From a german Bosch document I get this description:
einsteckbarer elektrischer Anschluss aus kunststoff mit Zusatzwiderstand 3 ohm
Google translates it as:
insertable plastic electrical connector with additional resistance 3 ohm
Any better translation out there ?
Luckily, the heating element tests ok with the multimeter.
rpc356 08-24-2013 05:04 AM
Can you post photos of the -001 wur internals and describe how you disassembled (and presumably will reassemble) it? My -001 works, but the warm control pressure is a bit low. Have thought about opening it up to see if a general cleaning might help. And maybe there's some way to make modest adjustments to the WCP.
prebordao 08-24-2013 06:03 AM
I just opened a new thread for the disassembly.
They're fully adjustable for warm and cold.
Warm - screw on bottom
Cold - pin
