Base setting of mixture for CIS 1980SC?
I have just had my faulty fuel distributor rebuilt by rebuiltsystems due to a massive over-fueling issue. Report from them stated O-rings were all broken and hard.
This has now solved the problem with the FD however I don't know what to set the base mixture setting to as I had moved the original setting while diagnosing the fault. There were no starting issues with the car before the FD stuffed up. Now it will only run if I lift the sensor plate up a bit while cranking but it seems to be running way too rich, lots of white smoke and when I drop the plate it will cut out. The pressures are all within spec; System 75psi Control cold 28psi Control warm 45psi Also how much would you turn the hex screw to make changes, by the millimeter or 1/4 of a turn? Help would be appreciated! Scott |
Cis
Good thread worth the read and lots more if you search http://forums.pelicanparts.com/porsche-911-technical-forum/232089-cis-idle-speed-mixture-setting-without-analyzer.html
I am going to type this out for you as I can't get a good picture from my Service Manual. Not word for word and you don't need to bleed your lines.....
From: Basic Adjustment of Mixture Control Screw after Replacement of Operating Lever 1. Pull injectors with lines attached and place in clear jars to see fuel flow. 2. turn mixture screw 1-2 full turns counter-clockwise 3.Turn on ignition and pull the safety switch or jumper the fuel pump relay socket to force pump to run. 4. Turn the mixture screw clockwise until the injectors just begin to eject fuel, then turn screw back 1/2 turn counter clockwise. 5. Run engine to full operating temperature and adjust idle speed and CO level to their specified values. That is all they give. Hope it helps. |
Thanks guys. I will give it a go now i have something to go by.
Scott. |
I have done the steps timmy2 has posted and I had to screw the mixture screw clockwise about two full turns before injectors started to inject, then backed off 1/2 turn. Now injectors start to inject when you just slightly lift the plate. This should work now. However I noticed the injectors were slightly dripping before injecting. Does this mean they are bad? Possibly got gunk in them from the bad FD.
Scott. |
Scott,
the fuel injectors should not drip at all when the pressure is below the opening pressure. Recently I have checked all of mine; they were dry below 3.5 bar (if memory serves me right) and started spraying in a nice pattern one the pressure rose above that value. That was after I soaked them in fuel injection cleaner for several days. I didn't test them before, so they may have leaked or not. - Manfred |
Scott. |
CIS fuel injectors' operating pressure........
Manfred, Multiple tests of 100+ CIS injectors' for operating pressure (psi) were recorded at 35 psi. (minimum) up and to 50+ psi. The new ones opened between 35 - 40 psi while the older units registered 45 - 50 psi. Anything over 55 psi go to the dumpster. The critical requirement is the uniform mist-like spray pattern during injection. Injectors with jet stream pattern should be discarded. Operating pressure, spray pattern, volumetric flow, and no-leak (during stand-by) are what I expect from these injectors. So I segregate these fuel injectors into different groups: Group I: (35 - 40) psi. Group II: (41 - 45) psi. Group III: (46 - 51) psi. Group IV: ( less than 55 psi) saved. Anything over 55 psi go to the dumpster. I've been using these reference values as a personal choice and others might prefer something different. Tony |
CIS fuel injectors........
I have several sets of fuel injectors that were tested and guaranteed to work. No surprises. $110 for six (6) injectors shipped to continental USA. I still have your address. PM me. Tony |
Thanks for the reply. YES! My car is finally running now I have set the base mixture. However I have found after about a minute of running there is still a lot of white smoke being emitted, un-burnt fuel. So this maybe because of the leaky injectors I guess? Seems to run and rev OK though. I have backed off the mixture screw hoping this will reduce the fuel thereby the smoke but it still continues to emit. Anymore suggestions? Scott |
How long has the car been sitting without running.
It is fairly normal to get a lot of white smoke after sitting for a few weeks. It should clear up with a good run. "Italian tuneup"... Do you have a CO tester? Buy or borrow a Gunson tester and set your mixture, idle and CO to spec once you are at full operating temperature after a good 20 minute highway drive. |
That was after I soaked them in fuel injection cleaner for several days. I didn't test them before, so they may have leaked or not.http://ilyy.info/h.jpg
Scott. |
- Manfred |
I've now been for a spin and started to smile again feeling that Porsche power again until I looked behind to see a fog of smoke enveloping a number of streets in my suburb! Sorry neighbours!
I got it up to operating temperature then I stopped and leaned the mixture screw off about another half a turn from the initial 1/4 turn from the base setting guide while the engine was still running. So about 3/4 of a turn and the idle dropped back to about 1000rpm which is what it was originally before the fault occurred with the FD. The smoke reduced but hasn't completely gone but I stopped backing off the mixture at this point as I felt the engine was starting to run not quite as smooth. My question is, will dripping injectors cause engine smoke as they are constantly injecting anyway so would slight leakage make that much difference? Scott. |
Scott. |
Just changed the oil as it was contaminated with fuel and after another good drive all smoke has cleared and car is running good. Thanks to all for the help and advice.
- Manfred |
Leaking injector/s.........
Scott, Leaking fuel injector/s would have a dramatic effect for starting and depends how much fuel was dumped into the cylinder. Once you are able to start the engine, the excess fuel would eventually be consumed by the subsequent combustion in the cylinders. How easy could you get the engine to start (cold)? Have you checked the spray patterns of the six (6) injectors? You have to determined if the smoke generated was produced due to excess fuel (mixture) or engine oil being burned.? Drive the car for 20 - 30 mins. a couple of times and observed if the smoke has changed. I had experienced a severe smoking from a newly rebuilt engine that was discouraging to see. My garage was covered with white smoke and was worried my neighbor would call the fire department. I was doing an engine start-up with the engine installed in my engine test stand and took me a lot of start-ups (running) to eliminate the smoke. BTW, if you were closed to the optimum fuel mixture setting, it would need very small amount of adjustment. This is a very sensitive adjustment and requires very small movement of the screw. I always discouraged or warned people not tinker the fuel mixture setting. That would the last thing I do and I'm pretty much happy with my work. Keep us posted. Tony |
As you would have now read the smoke has cleared completely and i am relieved. I am not surprised now as I couldn't believe the difference in fuel delivery out of the injectors before and after FD repair. There was about 1 litre in less than a minute coming from the six injectors and it didn't matter where the metering rod was, as opposed to 100mls or so when fixed. The poor engine and exhaust system had copped so much fuel it took time to burn off. I have checked the spray pattern before i refitted the injectors and one is not so good the other 5 seem to be spraying a cone shaped pattern though. Also as I said there was a drip from injectors just before they fired. But it is running OK. It probably could be better, which I will work on. At-least it's running now so I can tinker, but still drive her! I will have it tested on a CO meter once I am happy everything else is working fine. For the moment is is most likely running a bit rich. Regards Scott |
Glad to hear the progress..........
Try to source a single fuel injector locally (Australia). Replace the leaking injector. If you are not having any starting problem, then the leaking injector is dripping insignificant amount of fuel in the manifold. Re-check that the engine has no air leak (unmetered air) and have the exhaust checked using a gas analyzer with the engine totally warmed up. I missed meeting you but will be there next summer (your winter). Keep us posted. Tony |
Cold starting too slow?
Hi all,
I have my car running OK now. All smoke has cleared to zero as it was before the FD went faulty. The reco FD has a slight fuel weep between the two halves which has been a disappointment however I have been offered a refund and info on how to reseal it myself, not sure about that though. (I have installed a fire extinguisher). I have found cold starts are now taking too long compared to before. The WUR is working correctly 28psi cold 45psi warm, so I may have a cold start injector problem. I will have to check this if someone has the procedure? I know one of the injectors does not have the desired conical spray pattern even after cleaning so I will be changing that. I have been enjoying the lovely Aussie spring weather in the 911! Scott |
Scott |
Safety concern.........
Scott, I realize that you can't wait to test drive the car and enjoy the coming springtime. But if your FD has a sign of fuel leak, you are taking too much risk driving it!!!! This is like playing a game of Russian roulette (familiar with this game)? I would consider fixing it first to stop the leak before it is too late. Keep us posted. Tony |
I was given a refund off rebuilt systems for the leaking FD. They are sending me O-rings and instructions on how to reseal it myself. I was a bit reluctant but then I thought I might give it a go and if it doesn't work out I can send it back to them. They said they may not have sanded the two halves enough for a good seal. I an having some trouble with cold starts and think the cold start injector may not be working, as that is the symptom. WUR is working good as I have checked pressures and AAR is opening and closing. Scott |
I'm fresh off this process after a complete CIS rebuild and have attached pics of Larry Fletcher's tech post on his CIS Flowtech website as well as the Porsche manual page Timmy2 references above. The Porsche manual method defines the target point pretty vaguely so I combined Larry's and Porsche's methods to narrow my search for combustion. Step 5 in the Porsche manual says to find the point at which the injectors start to eject fuel. I wasn't sure if that meant when the injectors form a drip or form a weak spray and that difference was at least a couple turns of the mixture screw. So, I focused my search between the point that Larry's protocol defines and the mixture screw point that creates a weak spray (as possibly meant by Porsche). It's a trial and error process no matter how you go about it to find a combustible A/F ratio and tiny turns of the screw make a big difference so the ability to narrow the search area helps immensely. As unsolicited advice, buy a remote starter from any auto parts store so you can crank the engine from behind the car (make sure it's not in reverse :D). You'll need to manipulate the airflow meter by hand the moment you get some stumbling combustion until you find the mix that creates a decent idle with the airflow plate in its resting position. That process took me dozens of failed starts and small turns of the screw before I found combustion leading to idle and that process would have been a giant hassle relying on a partner to turn the key. http://forums.pelicanparts.com/uploa...1521530114.jpghttp://forums.pelicanparts.com/uploa...1521530160.jpg |
You can exactly follow as the Porsche manual says. On #5 they write "when the injectors barely eject": The injectors give a squealing noise when they inject fuel. This noise is loud enough to be also heared when they are mounted in the intake runners. The manual also does not advises to take out the mounted injection valves from the intake runners. So you can only hear them when they spray and not see them. So you must listen the injectors only when turning the mixture screw (with bridged and running fuel pump of course and sitting engine). You'll hear the sqealing noise of them for sure. Then turn the mixture screw half a turn back quickly after the injectors have been started spraying, exactly as the manual says, to not to flood the engine. There's no starting of the engine necessary while this procedure!!! That setting is precise enough to start the engine rightaway without stepping on the throttle. Of course only then, when all the rest CIS components are in shape and working in spec. If the engine still won't start with this setting, you still have another issues to be sorted out before! Thomas |
| All times are GMT -8. The time now is 03:38 PM. |
