-   -   3.2 Compression test - what to disable fuel/spark? (http://forums.pelicanparts.com/porsche-911-technical-forum/767755-3-2-compression-test-what-disable-fuel-spark.html)
r-mm 08-25-2013 07:32 AM
Quick one - how to disable fuel/spark to do a compression test on a 3.2?
Joe Bob 08-25-2013 08:00 AM
Pull the coil wires to the distributors.
r-mm 08-25-2013 10:11 AM
And just let the gas flow?
911pcars 08-25-2013 10:39 AM
Do you know how to connect a remote starter switch (to the solenoid)? If so, disconnect the DME relay under the seat. That should disable the fuel pump and ignition system.
Actually, I'm not sure doing the above will disable the cranking circuit. If not, just pull the relay and proceed with your compression tests.
Sherwood
db_cooper 08-25-2013 11:51 AM
Remove the holder/relay and pull the DME relay under the drivers seat. No fuel and spark. Good time to replace it with a new one from our host and put the old one in the glove-box as an emergency spare.
Sboxin 08-25-2013 11:52 AM
Please refer to Pelican's Tech article
Pelican Technical Article: Time to Rebuild? - Part II
Remove DME relay and fuel pump relay
The article also discusses the removal of the spark plugs cold and hot conditions
Regards,
James Brown 08-25-2013 10:12 PM
use the remote starter switch, pull the coil wire, put in neutral, keep key in pocket, pull all plugs.
make a copy of above and laminate it to the remote starter cable so the next time you know
Eagledriver 08-25-2013 10:19 PM
Don't forget to open the throttle while doing the test. I just put the center distributor wire next to a ground so it can spark there harmlessly. I let the fuel flow, (never noticed it).
-Andy
E Sully 08-26-2013 04:22 AM
Just pull the dme relay, don't disconnect anything else. Keep the gas pedal to the floor.
r-mm 08-26-2013 05:34 AM
Thanks everyone. Couldn't find these procedures in Bently. Pelican link is great.
db_cooper 08-26-2013 05:56 PM
Just be careful with random sparks from the coil/spark plugs with the fuel injectors energized and the fuel pump running, if you go that route. That's why removing the DME relay is suggested.
Saw a film of a fuel injected VW bus being tested using the easy short cut method..pull the coil wire and while doing a compression test..the fuel vapor from the spark plug hole(s) ignited....burning down a garage.
john walker's workshop 08-26-2013 06:33 PM
on the rear shock crossmember, just to the right of the upper left shock mount is the DME plug to the injectors. unplug it. easy and accessable.
