LinkBack | Thread Tools | Rate Thread |
Weber 40IDT With a stuck air mixture screw and now cracked shoulder...
Working on getting my new to me webers stripped down and was working out a screw that is stuck... Well I ended up cracking the shoulder. Any thoughts on how to proceed from this point? Any insight is appreciated.
Thanks in advance! Casey
Designer King
JB Weld?
You may be able to get some in there and get the 2 parts clamped together until cured. You could run the screw in and out while curing to chase the threads clean.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-28-2014 at 01:55 PM.. |
I've repaired several of these by replacing the boss with a press-in boss of original proportions and then re-machine the inner throttle bore to clean up the part that sticks into the bore.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
Thanks Paul. I sent you an email about this yesterday. Please let me know, also wanted to get some items on order.
Casey |
