Rubber O ring -thermostat
There appears to still be a trickle of oil from the thermostat even after replacing the rubber o -ring. Motor is a 73RS MFI type. Should I try another O ring? Any ideas or first hand experience appreciated. Thanks!
Old 08-27-2013, 04:39 PM
db_cooper's Avatar
I've had the same problem..if you are talking about the thermostat on the top of the engine case.
Our host sells two, one green and one red.
I used a green "O" ring and the thermostat glided in with no effort..and it leaked oil.
I used the red "O"ring..the thermostat took some mild effort to install..(lubed of course) and has not leaked a drop of oil.
Same part numbers..different results.
Old 08-27-2013, 04:46 PM
Thanks.... Hmmm I used the red too. Maybe ill just buy a new ring and give it another go.
Old 08-27-2013, 05:04 PM
Might try a bit of Curil-t on the o-ring
Kinsley
1980 SC Targa - MS2, EDIS
Old 08-27-2013, 05:38 PM
db_cooper's Avatar
I would try another "O" ring different color. I would not use any sealer. They don't leak with a good "O" ring in them.
Old 08-27-2013, 06:34 PM
db_cooper's Avatar
Went back through my log..the RED "O" ring was the oil leaker..the GREEN "O" ring worked..sorry I got it backwards. Use 999-707-314-40-M17 GREEN
Old 08-27-2013, 06:39 PM
oil leak
ahh...thanks ill order the green
Old 08-28-2013, 09:11 AM
