nostatic's Avatar
how many fuel pump relays?
I thought that the relay for the fuel pump relay in a 3.2 car was contained in the DME relay (C-618-154-00). But on the PP catalog they say the red relay is for up to '89 cars (C-615-108-01). Are there 2 separate relays? I also seem to recall Warren saying that the red relay could be used for others in a pinch...so it is worth keeping one around (yeah I know...only if you actually own a damn car).
Old 08-07-2002, 02:42 PM
marcesq's Avatar
The 3.2 with DME only has one fuel relay and it resides in the DME relay, actually the DME relay provides a ground for the fuel pump fuse.
The reds are the same as the blacks except they can handle higher amperage.
Having a car doesn't have anything to do with having knowledge!!
Regards,
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 08-07-2002, 02:46 PM
Hi:
With all due respect..the reds do *not* handle more amperage than the blacks. The reds have an internal diode for those circuits that can't tolerate "backwards" current flow...acts as a "check valve". Result: You can use reds where blacks were used originally...but not vice versa.
---Wil Ferch
Old 08-08-2002, 06:17 AM
