-   -   How to install a 901 in a 1972 (http://forums.pelicanparts.com/porsche-911-technical-forum/768191-how-install-901-1972-a.html)
lrodri64 08-27-2013 05:02 PM
Hi,
I'm going to install a 901 and a 2 lt engine in my 72 and I need to mate the 72 shaft to the 901 transmission. I have a 911 transmission outer shaft couplers but would need to machine the part to fit in the 901. Have someone done this? I did a search but not great info. Maybe iam using incorrect words on the search tool. Please advise.
I have 2 different sets of the transmission coupler, both sets are 4 bolt 2 studs course spline type but one set is about 1/8 of a inch shorter.
Please advise,thanks
Trackrash 08-28-2013 01:30 PM
Check this link.
http://forums.pelicanparts.com/porsche-911-technical-forum/591069-cv-joint-axle-half-shaft-compatibility.html
RWebb 08-28-2013 01:31 PM
you will need an adapter/shim if you use a 915 type crossbar
vintagecarlover 08-28-2013 02:19 PM
Just curious, why are u doing this install?
lrodri64 08-28-2013 08:29 PM
Hi, it is temporary. Until I finish my 3.0
Trackrash 08-29-2013 08:44 AM
Will you be keeping the 901 trans with the 3.0? Seems to me, sourcing a 915 and selling the 901 would be the way to go, everything considered. Especially if the trans you are installing is one of those 901/911 transmissions with the weak ball pivot.
RWebb 08-29-2013 12:36 PM
the 901 & 911 transmissions have a nicer, lighter feel to them than the typ 915
more importantly, they have the wonderful road-racing shift pattern - the 2 to 3 shift is right in a straight line, perfecto, just what you want, etc.
I would keep the 901 in there "temporarily" until you blow it up
