I've been perusing all of the info on Pelican regarding the shift coupler bushings housed in the tunnel in front of the rear seats
Brad |
I don't know if the Pelican article mentions it or not, but you should have marked the longitudinal position of the coupler body on the shift rod with an indelible marker before you took it off!
------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler |
Brad,
What you need to do is make sure your transmission is in the neuteral position. Next slide the coupling over the shaft After that, engage the clutch Steve |
Oh ok, so the general consensus is that I sorta doomed myself
![]() fantastic! I guess i'll just try to move the coupler forward ![]() Brad |
Senior Member
Hello
The messurement is done by the position from the shift lever in one forward gears. Enough space to avoid hitting the knee bar/ashtray with your knuckles. Grüsse |
You have not "doomed yourself". The basic fore
------------------ Paul 1984 911 Targa 1986 911 Coupe |
BLizzard describes the procedure in the Haynes manual - I did this a week or so ago for the 901 transmission (it is opposite though)
Bascially the hard part is understanding if the gear lever moves left the coupler rotates right. Gear lever forward, coupler back... So that method sets the left Cam [This message has been edited by CamB (edited 08-28-2001).] |
I did the same thing you did. It took me a while to get right but now it has never shifted better. Just need new motor mounts now
When I had my engine
When the trans shaft is pulled forward, it can only go into 1st or 3rd gear. From that point, you can slide it towards the rear until it disengages - this is the neuteral position. If you slide it furthe back, it goes into either 2nd or 4th. If you rotate the trans shaft to the left when you start, you will go into 1st gear, if you rotate it to the right, you will go into 3rd gear. You need to have a starting point when you start. If it's in 1st gear, set your shift lever to the left forward, etc. Once you get to this point, then you can work from there to get the shift lever in the right position. Not a real hard thing to do. Steve |
Thanks for all the great advice guys, I'm going to give it a try this evening. Tried to bang the pin out of my old one
![]() Brad |
Ooooo, that reminds me. I replaced the bushings in my coupler,
The OEM bushings actually have an oval-shaped hole for the pin: __ (__) The Pelican replacements don't have that extra play, One last thing: Don't be afraid to move 2nd gear back towards the seat some. A lot of folks say you should adjust the shifter so that 2nd gear stays well away from the seat, etc., but I moved mine back so I have a finger's width of clearance. The result? 1st, 3rd, Replacing all those bushings makes a big, big difference in the feel of the 915. I strongly recommend it. ------------------ Mark Szabo 1986 911 Targa 3.2 1987 Escort 5-speed 1.9 RIP The Porsche Owners Gallery |
Aftermath: It's done! Got the new coupler with bushings
One more question, didn't fix a 1st to 2nd balk I've been having Thanks, Brad |
Senior Member
Brad,
What type of fluid are you running in the gearbox? If you do not have Swepco 201 in the box now, its time! I put the swepco in my 915 box Joe |
