Hey all,
Man I just found this bulletin board. Way cool. OK, I have an 88 that is needing some sunroof parts. I need the two little levers (?) on each side that lower the wind deflector. What are these called so I can make sure I get the correct part from Pelican. Also, I think there are some clips along the front edge of the wind deflector that holds it on maybe. My sunroof jammed when the lever broke and I managed to get it closed. Can't open it right now to look at parts due to rain. Any help would be greatly appreciated. Thanks, Mark |
911.564.127.00 hinge 2 needed
911.564.123.00 clip 2 needed |
John,
Wow that was fast. Can I get these from Wayne at Pelicans? Thanks, Mark |
most likely a dealer item.
Pelican carries the parts you need, e-mail Wayne if it's not on the website.
------------------ Josh Black on Black '84 Carrera |
I recently popped those clips while cleaning the wind deflector and am unable to get them back in place. Does anyone have a diagram or simple explanation? Thanks
Jeff |
