Question SC misfiring - what's left?
Guys, after sitting for 2 weeks and running great, the car starts up like always but misfires right away. have checked all the ignition parts, new fuel pump, etc. I am getting spark to all plugs and fuel. Any ideas? CD unit going bad? 81'SC This is a sudden problem.
Old 08-08-2002, 05:00 PM
Early_S_Man's Avatar
Have you looked at the 'green cable' as it exits the distributor and makes a sharp turn? They often crack both external and internal insulation there and develop intermittent shorts which interrupts the signal to the CDI-unit!
Pull the 6-pin connector to the CDI-unit and chexk for the proper 600 Ohms resistance at pins 31d and 7 ... decal on side gives pinout. While monitorong the resistance, have assistant wiggle the green cable at distributor (or vice versa) and watch for momentary changes in the meter reading!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-08-2002, 05:13 PM
