Clutch Fork Question
I'm in the process of re-installing my gear box but came across a small dilema;
after we removed the box we noticed that the fork shaft only had one bearing ( the one with the hole which face the outside) Now, I'm trying to install the shaft back the correct way with the two bearings, however, if I do that the plastic cap that serves as the lock won't work, what is the correct way? The box already has the upgraded brass bushings. http://forums.pelicanparts.com/uploa...1378082825.jpg |
| All times are GMT -8. The time now is 10:15 AM. |
